Ant Selector
BigLou
Well-Known Member
May 15, 2018
321
329
SW FL.
I just got a Fire Bird-500 SW-4 antenna selector it looks like new. It has no paper work with it and i cant find any info on it.If anyone in the Forum has any info on this i can use it. I have the Fire Bird 500 Amp and need to no how much power the ant selecter it will take..
Reactions: Tokin
Open it up and post some pics.
Reactions: sunbulls
If you can't post pics, does it look like the Dosy SW-4? Maybe it’s a re-labeled clone. The Dosy is rated at 1KW, but ratings are subjective. As long as you don’t switch antennas while transmitting you should be fine for what you’re running.
Reactions: Tokin
