Cobra XL-450 Amplifier
FredTx63
Well-Known Member
Oct 17, 2015
205
213
53
63
For sale: Cobra XL-450 Amplifier in pretty excellent condition.
The only real flaw is fixable. For whatever reason, the previous owner decided the engraved labels for the two SO-239 connectors weren't good enough and had to write their labels with a sharpie on the back of the amplifier. This would probably clean of pretty easily. Other than that, it's in excellent condition and does what it's supposed to.
I've included a picture of the inside, looks all original to me. Too bad the ground strap common to the 4 transistor models of these amplifiers cover the markings on the transistors - look like Toshiba markings to me? Could be 2290s.
Either way, these are desirable for their effective AB biasing & filtering circuits making them ideal for producing clean output on SSB.
$300 shipped CONUS prefer PayPal for payment. PM me if you want it.
The square blue trimmer pots near the front looks like adjustments for biasing. Not familiar with that amp. But if OEM or not, still a good thing just the same . . .
Sommerkamp, never saw a missed call? I'm taking the amp to my tech this weekend to have him check out the discolored resistor pointed out above. Once that is replaced (if necessary) and given a 100% clean bill of health I'll PM you - shouldn't take but the weekend.
That baked resistor is a casualty of over-drive...
Why do they put those silly power level switches in there, anyway?
I am no expert, but the first thing I do when I am re-furb'ing an inexpensive leenyer is pull that prone-to fail / prone to cook mess out of there and bypass it with an adequate wire.
AND STOP OVER-DRIVING THE AMP.
Drop the input wattage down lower and let the amp amplify, rather than increasing the input wattage and dropping the input / output with a resistor.
Reactions: undertaker
The Amp is not made for "10 ohm smoke" it uses 18 ohm - so the Transistor it's paired with, pushes the Base a little higher up from Class C.
This amp was designed to run low, not as a poor performer, but done up for long-term survival in conditions that may be less than ideal.
It can explain the reason for the discoloration of the power resistor - chatty people, SSB for Skip - having to repeat the directions to the Doughnut shop - repeatedly - for those needing a sugar rush washed down with caffeine - wear and tear - but @ButtFuzz mentioning the requirement and the proper means to drive it - certainly applies to and for anyone.
(y):)(y)
Sure, it may not be stellar power performer - the design puts this into a category by itself - sure - it's gonna' have a little more heat, a little less power, but it has a cleaner output - doesn't make it better dollar per watt wise, it makes it cleaner and better in the Cost of that Watt in the usability and lifetime use in-between Mean Time Between Failures (MTBF).
If it works, don't fix it.
