Need a new Multimeter - Fluke 117 or 77-IV or ??
Ham Radio Nerd
Apr 14, 2002
9,321
2,011
383
My trusty old Fluke 73 III multimeter LCD is dying. So, I've been looking around at new models. So far I've landed on the Fluke 117 or the Fluke 77-IV but the differences between them aren't super apparent to me. I've also toyed with just buying a cheap Chinese one, but I'm leery. I also suppose that a different Fluke meter may be a better choice so I'd like input on that, as well. I'd like to keep the cost under $300 if possible.
What would you do?
If its just the display segments playing up or missing its common and an easy fix,
remove the screen & clean the rubbers & glass where they sit with iso alchohol & reassemble, its part of owning a fluke for years,
I have a 117, an old 77 & a couple of older 87's
the 117 is aimed more at electricians than electronics but its good enough for what most Hams use a dmm for, its true rms meter, volt alert & low impedance input are ok to have,
the 77 iv has higher resolution current range & measures up to 1000v, its not true rms & not all of its specs beat the 117,
looks to be a lot of difference in cost if the 117 does what you want it to,
I have had plenty of china meters, some sexy looking with more functions & larger prettier displays than my flukes, nowhere near fluke quality but they do usually work & reasonably accurate,
I would try cleaning the 73.
Hello Moleculo: I have both a 117 and a 77 and they simply work great. The only thing that I have done is to make a set of test leads with mix 31 chokes and a 1000pF cap bypassing the leads to keep RF out of the meter. Is work good G.I.
Of all the meters I own and the company supplies, the 87V is my favorite for everyday troubleshooting and measuring. It has a temperature function, which I use a lot and is also amp clamp compatible, AC only, I use the 374 FC for DC....Speaking of, the 374 FC may be something to look into.
I own a few meters....the 772: mA clamp with source, simulate & measure. 787 process meter: not worth the investment unless you deal with 4-20 often. 374 FC: a very well rounded meter clamp, it has BT so you can actually be away from your meter and watch changes on your phone as you make changes in a circuit or throw a switch/push button, ect. and the 87V: which as I said is my go to in field meters.
You may also want to look at the 83V, it's probably the closest in functionality to the 73.
I say if your willing to drop $300 on a dmm, just spend the $100 more and get the 87v. A meter you will have for life
A few years back I went through all the same questions. I ended up getting a super good deal on a Fluke 179. I can not believe how much the price has increased. Do not forget to change things around if you do ma. The fuse is very expensive. I now have a Simpson analog I use for that so no more 8 dollar fuses for me.
I keep this in my toolbox.
It is cheap, rugged and has served me well for less than $70 bucks.
Sperry DM-6400
I know it is not a Fluke, but for a basic meter it has held up well bouncing around in the tool box.
Reactions: Slowmover
Got lucky a few years back and scored an 87 Series III used on ebay for $50. They are super-high accuracy on DC Volts - great for radio-electronics work, and is like a $375 meter.
With Fluke quality and free lifetime warranty repairs on most meters .... I can recommend looking for a used one and save some $$
