AMERITRON AL-811H replacement relay
Crambone
Well-Known Member
Jan 22, 2019
563
175
53
58
anyone know a replacement relay I can use for the AL-811H? AMERITRON is backordered.
I just ordered three of them from this outfit. The original Ameritron relay will arrive from the factory with the contact points visibly misaligned. Causes uneven wear and intermittent contact. Sometimes in receive, sometimes on transmit. Sometimes on both.
Well, that's we we found the last half-dozen Ameritron amplifiers that came through here. Brand-new replacements from MFJ/Ameritron were the same way.
Sure hope this part's pins line up with the circuit board holes.
Yes the receive is horrible when using the Ameritron
