Shakespeare big stick 3
Two other points of interest with the original Big Stick antenna. One is they do not handle a lot of watts and some have built in clocks that only allow operation with a low VSWR, during daylight hours...
I know the second symptom sounds ridiculous but I have seen more than one Big Stick with a VSWR that climbed into the red, every night it was damp enough for dew to form outside. Oddly enough, rain did not seem to mess it up but high levels of condensation in the absence of sunlight, did make the problem appear consistently.
I suspect some had sealing problems in the base matching section that allowed enough condensation to build up on the matching coil, that it shifted the impedance substantially. Every morning that started with a high VSWR, would result in it dropping to a 1.2:1 by about 11 AM, with several hours of sunlight drying out the condensation. Me and my Uncle had the same exact problem with Shakespeare antennas purchased through Radio Shack in the 1970's.
The Radio Shack Blue Stick which replaced the Shakespeare, was far worse since it was sold with a 100 watt firecracker in the base of every one. Hit it with 100 watts and it pops like a firecracker. Incidentally neither one of the old Shakespeare antennas, was ever hit with more than 12 watts PEP. We didn't have linears back then.
Reactions: secret squirrel
Apologies for not adding anything constructive to your post. I had answered with the sarcasm. A NOS Shakespeare Big Stick is on a list of I would like to find items. My father ran a Robyn LB23a in his Suburban to a Shakespeare. If that CB put out 12 watts that would be great. I remember having to tie it down when he pulled in side the garage. That was big in the day when we all wanted a GI Joe with the Kung Fu grip for Christmas.
Reactions: Slowmover
hey I have a Sirio performer 5000 with the 145pl magnet mount I want to know the cable it comes with is not long enough to mount it towards the rear of my cherokee.,the 12' cable that came with its no long enough any ideas where I can purchase the 5 meter cable or can I use RG400 or LMR 240uf thanks sorry if it in the wrong section didn't mean to hijack the thread if I'm wrong sorry thanks
Unfortunately you have the early model because I have the 145 PL with the 5 meter coax. I've never used my 145PL and maybe we can do a swap? Or, you can order a 3' -6' jumper with a barrel connector.
Reactions: milocs
Well mine has an almost flat match night or day so idk maybe that was a bad one?
