Cb tricks and similar board as the 979 should get you close. It's suggested to have it done with the proper test equipment.Needing a little help setting my hi and low variable power. I'm aware of how to do this, just can't find any info on the 939f vr adjustments. Needing pow, high, and modulation. Any help much appreciated! Tia!
Thanks alot, was able to do some referencing, and they are pretty close!Cb tricks and similar board as the 979 should get you close. It's suggested to have it done with the proper test equipment.
