Galaxy dx 939f vr adjustments
410onAM
New Member
Jul 8, 2021
14
9
3
43
Needing a little help setting my hi and low variable power. I'm aware of how to do this, just can't find any info on the 939f vr adjustments. Needing low, high, and modulation. Any help much appreciated! Tia!
Needing a little help setting my hi and low variable power. I'm aware of how to do this, just can't find any info on the 939f vr adjustments. Needing pow, high, and modulation. Any help much appreciated! Tia!
Cb tricks and similar board as the 979 should get you close. It's suggested to have it done with the proper test equipment.
Galaxy 939F
VR18 Low power adj.
VR14 High power adj.
VR16 AM Modulation
VR15 Meter Modulation cal adj.
VR9 TX Meter adj. (Radio keyed)
VR1 Rec. Meter adjustment
Reactions: olecobraguy
