How many truckers are running VHF ? Is CB dying ?
Not an OTR driver/trucker, but I usually carry a basic AM/SSB CB and a 2 meter simplex radio in the vehicle when traveling the interstate highway system. Will run both simultaneously, CB Ch19 and ham 146.52 simplex if the vehicle has two antenna mounts, otherwise one or the other depending on weather/mood. CB for bad weather for staying alert to road conditions. Sometimes if I get super bored I'll work skip on 38 LSB, but operating a clarifier while driving is a pain.
For something in the vehicle for local travel (< 500 mi) I find myself more and more gravitating to the GMRS linked UHF repeater system here in the Albuquerque/Tucson corridor. https://swcrs.org/ and system map attached. It's a bunch of GMRS repeaters using wideband deviation that are linked with AllStarLink technology, but it's a sparate network from the ham VHF/UHF AllStarLink system. I'd say half the users are CBers who got a GMRS callsign, and the other half are hams who got a GMRS callsign. If the FCC lowers (has lowered?) the license fee from $70 to $35 there will likely be more people moving over.
Anyway, if you have a linked GMRS system in your area, give it a try. UHF linked repeaters may be where things are headed. I understand they've been the thing in Australia for a long time.
Thank you for the picture of use you provided.
The hams only had it starting in 1947 when the 29.7-30.0 MHz segment was re-allocated from the hams to gov't. And 27 MHz was an ISM band already. So, the hams were given a piece of an ISM band for 11 years, 1947-1958, and then it got taken away. If you want to complain, go tell the gov't you want 29.7-30.0 MHz back, as that was the original "theft" of 300 kHz. Quit complaining about the 27 MHz band.
Thank you! Good to know I'm not alone. (y)
I'm not sure that MURS with a 2 watt limit on VHF and FM modulation has much utility. There aren't a lot of "type accepted" or "certificated" MURS mobile radios; Wouxun MURS mobile radios like the KG-1000M are selling for north of $300. The northwestern Canadian LADD VHF frequencies would be the prototype for trucking, those are required to be licensed and are 30 watts. So not sure what to do with an unlicensed 2 watt VHF radio in the mobile environment. $300 is a lot of coin for a 2 watt radio. I run a $140 2 meter rig at 35 watts typically on 146.52 simplex, can boost to 80 watts to complete a conversation if range gets spotty. The idea behind MURS was to legalize the practice of people taking their VHF "colored dot" business band HT radios on hunting trips, etc., not to create a new unlicensed mobile radio service for trucking. The Alaska Trucking Association had to get a FCC license for 12 channels of VHF at reasonable power (up to 75 watts) for use up there, similar to LADD. But again it is not an unlicensed service like CB or MURS or FRS.
Your post is right on the money!!!
Since you said that you run both CB&VHF I am curious about the Antenna. Do you have an NMO mount and you switch coil&whip between the two or do you have a CB antenna in the middle of the roof and the VHF on the fender?(or other location?)
Reactions: Slowmover
Truck has an NMO properly drilled into the roof of the crew cab, and a 3/8x24 bolt-on on the tailgate. Typically run VHF or UHF on the NMO mount, and CB / 10 meter 102 inch whip on the tailgate with a MFJ tuner. The 102 inch whip is pretty broadband, over 2 MHz wide, so it sort of works from 26.9 up to 29.6 MHz with the tuner. Stands at 13 ft 4 inches from asphalt up to the tip.
Passenger car has a single trunk lip NMO mount for either VHF, UHF, or a Larsen NMO27C low-band for CB. Have to choose a band before rolling out.
I have been checking out mygmrs.com, we use Midland handhelds to talk between houses in the neighborhood. I have a gmrs license and run a Midland 115 in my base station. I don't have any repeaters in my area, but sometimes I can hear one self ID ing. I need to get a real antenna up, right now I have the micromobil mag mount on the coat rack in the shack.
Truck has an NMO on the roof of the crew cab, and a 3/8x24 on the tailgate. Typically run VHF or UHF on the NMO mount, and CB / 10 meter 102 inch whip on the tailgate with a MFJ tuner. The 102 inch whip is pretty broadband, over 2 MHz wide, so it sort of works from 26.9 up to 29.6 MHz. Stands at 13 ft 4 inches from asphalt up to the tip.
Good to know, thanks. I am installing a NMO in the middle of the roof of my truck and plan to use it for both VHF and CB, with the option of a fender mount for the VHF if using both without switching antennas. I also favour LARSEN (used them for a lot of years for commercial VHF) but I was going to experiment for the CB band by using the NMO30 coil and 64"whip for 27MHZ (you can also use the NMO34 with the 64" whip for 10m). I posted the writing on another thread. You have to order the coils and whips separate because Larsen doesn't sell these as antennas, but there have been good reports on them and you can use power up to 150-200 watts.
73.
Hey Slowmover, while on the subject, what do you use on your big truck? Dual antennas on the mirrors or a single one in the middle of the roof? I know that with some of the trucks it is a task to get good performance for many reasons(still have try though)!
73.
I'm not sure that MURS with a 2 watt limit on VHF and FM modulation has much utility. There aren't a lot of "type accepted" or "certificated" MURS mobile radios; Wouxun MURS mobile radios like the KG-1000M are selling for north of $300. The northwest Canadian LADD VHF frequencies would be the prototype for trucking, those are required to be licensed and are 30 watts. So not sure what to do with an unlicensed 2 watt VHF radio in the mobile environment. $300 is a lot of coin for a 2 watt radio.
In Maine the timber companies use it on,the woods roads. I have no idea who's using what. But in a recieve only fashion I can monitor it when using the woods roads. Not to mention if I needed assistance CB and MURS is heavily monitored and I'm more likely to find someone there than ham or GMRS. I operate the equipment for the area I operate in.
Reactions: Slowmover and cralt
