Sears RoadTalker Road Talker 40 Model 562 Base / Mobile CB Radio power cord
danmcclain
Dec 11, 2020
1,301
819
123
75
Looking for a 110v power cord for the above radio. Any help would be appreciated. Thanks, Dan
Heres what i found at kens
http://www.kenselectronics.com/lists/pwrcord.htm
CEA-CRST-AC fits Hitachi-5: Cobra 85, 86XLR, 135, 135XLR, Sears 562.3820700, Penney, RCA, Zenith
Thanks, but the pin configuration is a bit different....
Reactions: Tokin
I have a feeling that the only cord you're going to find will be a 2 hole plug that fits the 2 ac pins with the 3/8" spread as described at Kens. I dont believe youll find that 5 pin plug unless someone here has one squirreled away. In any case call Ken and he'll know what will work.
Reactions: AudioShockwav
Thanks Tokin, will call Ken and see what he has to say... And if I remember right I may have some 2 hole plugs...
Reactions: Tokin
I have a feeling that the only cord you're going to find will be a 2 hole plug ..........
Ken is a great resource for a lot of old stuff, I was working on a old Robyn 40 ch AM radio that had a bfo so you could rx ssb on it.
Ken had a service manual for it, not a photocopy but a actual factory manual and he sent a owners manual with it.
He is good people to deal with.
I lived 2 miles from kens for 20+ years. Kens is one of the reasons i got into radio. Hes definitely a pack rat and throws absolutely nothing away. His shop back in the day was so packed full of stuff you could hardly move around.
If you needed something obscure you could bet ken would have at least one squirreled away. I wish i had more reasons to spend money in his shop.
Thanks for the info Jeff, I'll check it out...
