This morning as I was upstairs getting ready to address the day I went to the radio room and decided to turn on my GE Super Base just to see if anything was coming in. On my Super Base I had my Dipole in the attic hooked to antenna port B and I was Amazed the DX that was coming in with almost No Air Noise ( static ) on 38 LSB. So out of curiosity I turned my McKinley on that was hooked to my Star Duster on the same channel and it came in But with much Air Noise. I turned it off and hooked the Star Duster to antenna port A on the Super Base and flipped the antenna switch and again the Star Duster was full of static while receiving. So as a last test I switched the two antennas around on the Super Base 2 Ports and again the Star Duster was Noise y while the Dipole was Very pleasant and almost noise free. Which brings me to ask the question, Is that the way Dipole Antennas are ( less noise y ) ? Or was it just a Fluke occasion. I never used the Dipole much because I have to get back in the attic to shorten it to improve the SWR and even it out across the band. The SWR isn't Bad but I know I can make it better. I put it up in the attic as a experiment because 1 operator always bragged about the merits of a dipole. When I first shortened and tested it on the ground it performed excellent but the SWR climbed when I put it in the attic so that is why I haven't used it much. ( TOO hard for a old guy to crawl around in the attic ) LOL But if I can expect more quite receive, then my Buns will be in the attic as soon as it warms a little. For those who wonder it's in a inverted V pattern as it follows the peak of the house. Have at it !
