New Sirio 5000 performer
seedkey
184
40
Hi,
I just bought a Sirio performer 5000. Didn't come with a mount
Any of you guys know what mount I should use for roof top mounting? no magnets.
Thanks in advance
Seed
If you have the most common version that requires an SO-239 mount...
https://www.sirio.store/index.php?main_page=product_info&cPath=2_88&products_id=397
Here is an Amazon link to the mount by it self.
... or not, the forum is trying to insert an amazon link as a media file??? Odd.
Anyway, as it shows in the link above, the model number is SG/AC-U SO-239, search for that and you should find it.
Some companies on the ham radio side make SO-239 mounts as well, such as this trunk mount from Diamond.
https://www.diamondantenna.net/k400s.html
If you get a trunk mount you should make sure you get a heavy duty version.
In a pinch the Wilson mounts for the 1000/5000 series antennas should work as well as those antennas have the same type of plug.
If you have the version that has the standard 3/8 in stud, there are many more options available.
The DB
