Cobra 138 23 Channel, SSB Manual
Bombardier
Dec 19, 2021
41
11
18
57
Hello,in need of the Cobra 238 23 SSB manual,need to allign,any help is appreciated. Thank you, have a great day.
Looks like it may be Sams CB-57.
I have the Sams book for that radio, I no longer have a scanner but i can try to take a clear photo of it and post it later on this afternoon,IMG_20220617_152034.jpgIMG_20220617_152104.jpg
I can share one nugget of experience with that model. Never, never never adjust VR15, the sideband ALC for more than 3 Amps max draw from the radio's power supply. We learned the hard way to check for this before the covers go back on. Reason for this is the main T/R relay. It's built with thermoplastic that gets soft if you run the relay too hot. Causes the hot and ground sides of the relay's power-switching circuits to sag and short to each other. Pops the main fuse, unless it has a "no-blow" fuse. Then it pops circuit-board foil traces. The relay has a pretty strict upper limit of 3 Amps.
That relay looks like an american-made 'cradle' relay, but the pins are not arranged the same. A japanese-made relay is the only thing that will work in that radio. The pins on the american-made type will line up with the holes in the circuit board.
But it won't work.
    63Sprint has left the room.
