President Andy, 4 pin microphone
Groundhog KSS-2012
Well-Known Member
Sep 8, 2019
300
324
Does it hurt or, will it affect the President Andy radio in any way if I use a 4 pin power mic on it?
Many Presidents are 6 pin but the Andy I bought new last yr is 4 pin.
These radios come with an "electric", factory mic, I believe. I think I read that.
Just looking for a bit of info before I go and try one and mess something up.
If anyone know, I really appreciate hearing from you.
Thanks in advance
Thanks in advance
If i remember correctly I believe the only thing is you'd need to disconnect the wire from either pin 4 because it isn't needed.
Another thing would be the voltage coming from pin one. You'd need a capacitor from audio to ground inside the microphone.
There's a thread on the president lincoln where another forum member did the research on this subject. Just have to find it and it could help you in this endeavor.
Reactions: Groundhog KSS-2012
Thanks for the info. Greatly appreciated.
Not the same radio but the same concept with the audio pin.
Credit to @Dr_DX for working on that and schooling us.
I have an Andy II FCC and you can switch between Electret and Dynamic for the mic. I have mine set to Dyna and am running a really old Astatic D104 M6B. I just checked your manual and it appears that is a feature President added to the Andy II. But I ran that mic on a Uniden Pro 520XL for 35 years with no issue. Bought the pair in 1987. You may want to contact President-USA @ +1 239 302 3100 and verify.
Write your reply...
