what are these gizmo for
1iwilly
Dec 7, 2008
915
653
103
64
well got a chance to look at my new to me cobra 2000 gtl boy this off got some stuff on it that has me stumped 1 gizmo looks like it's for modulation because it has a wire connected to vr12 AMC then another gizmo with a longggggg trimmer have no idea on that one radio does work but it needed a little help clarifier is open
Just a guess, but that "longggggg trimmer" may be a 5 kc jump. I've seen something like that done in a Cobra 132 XLR.
Or it could be something to have switchable "broadbanding" of the VCO if its proximity to that circuit is any clue.
Only real way to find out for sure is to trace the wires controlling the relay next to it and flip that switch to see what happens.
The rest of it, no idea. The smarter people that hang out here will probably have some more ideas.
Reactions: Captain Kilowatt
your right took it off had to re-touch L19 to bring it back
The pic of the rear-panel 3.5 mm jack that was added has a pink wire that bonds the circuit-board ground to the chassis ground. Generally this is a no-no for radios like this built with a floating DC ground. And if it doesn't cause any mysterious "ground loop" noises, it won't be a problem. Only some of the modification wiring is visible, so not sure what that jack is about. The tiny circuit board with the transistor looks like a circuit to key a transmit relay.
Maybe.
Reactions: Rwb
Maybe.
i took all the gizmo off that 3.5 jack and including the 2 extra crystals for lower and upper channels put it back to stock as possible i left the clarifier open but align it at 12 o'clock
the rf meter doesn't work i spray contact cleaner but no go i also notice the volume is a tad like low compare to my other 2k
well meter is fixed good video on youtube on how to fix it dam meter going for $30.00 to $40.00 now for the low receive volume maybe a dirty pot
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
