Sears Roadtaker 40 SSB Base Station Model (934.38270700) Works but No Mic.
metalguy66
Aug 3, 2022
28
34
23
52
Roadtalker 40 SSB Base 934.38270700
The seller says they can hear local radio traffic coming across loud & clear even with no antenna attached.
A little bit of info on this model:
These are great radios. I have one. These were sold around 1978, built by Hitachi for Sears (and JC Penny as well). Great build quality and easy to work on. The VFO is based on the SM5104 PLL chip. There were lots of mods in the old magazines for these radios. Plenty of room inside too.
The internal 13.8VDC regulated PSU is a little on the weak side and most people reccomend using an external supply. I rebuilt the supply in mine and it does 4w full modulation AM and 12w side-band nice & clear without dimming the meter backlight. If you're gonna "Peak & Tune" it for barefoot transmitting, you want an external supply. Sears uses the same mic connector (5-pin DIN) & pinout as Radio Shack. You can get an aftermarket mic for $20 or an adaptor to 4-pin for $10.
Reactions: Rwb
i got a slant face road talker, channel mods done to it. works fine and is well built n very HEAVY. need to source a 12v cord for it some day. got a turner+3 mic wired for it and the original coffin mic also
NOS Sears Road Talker AM/SSB Base/mobile.
All hardware, power cords, bracket, box and hang tags.
Beautiful radio!
Solid info on that vintage rig — Hitachi built some reliable gear back then. Good to hear the seller is picking up local traffic clearly even without an antenna. Those old Sears/Philco CBs were built to last. Thanks for sharing the history on it!
