Okay, I give Up!
Greg T
WDX-945 (Jazz Singer) Upper Peninsula of Michigan
Sep 18, 2014
1,183
1,978
173
70
Escanaba, Michigan
Does anyone know where to buy 4 or 6 conductor microphone cable by the foot? I've searched for days on the interwebs, can not find what I need. I can find cable, but all the wires are shielded with one shield instead of just the audio wire. I'd like to get about 10 feet or so. Maybe it's okay to have all the wires in a shield? I don't know. Assistance would be greatly appreciated!
they also have shorter or longer lengths if you want.
Copper has it...
So, you're saying it's okay to have the control wires inside the shield with the audio?
i have used this cord before, and it only has the audio wire inside the shield.
I went down the same rabbit hole you did trying to find this type of cable and ended up buying the workman cable.
did you see something in the ad that said otherwise?
No, I just zoomed in on the pic and it seems as though the shield is the entire outer layer over all the wires. Maybe just a weird view. The workman cable has the single wire shielded?
yes only the audio wire is shielded in that cable i linked to.
just putting this here for future searchers or in case the heil cable doesn't work for you.
Reactions: Greg T
    63Sprint has left the room.
