SWR started acting sketchy the last few days. I disassembled the antenna and found the area inside the item circled to be full of corrosion. Only that area. Not sure if moisture got it from the top where the whip enters and ran down or if it got in lower and condensed up in that area. It was a combination of rust and white chalky nastiness, a real mess. I cleaned it up best I could and the SWR is back where it should be. If your 5000 starts acting up, you might want to have a look inside. Great antenna performance wise but not sealed at all against moisture intrusion beyond the rubber cap at the base of the whip.
