It's not a transistor, it's a SCR, or silicon controlled rectifier. Turns on like a transistor, but stays turned on after the input is removed. Only turns off when you remove the power. In the Cobra 2000 it's wired in parallel with the power button. Pushing the power button to "On" shorts across the SCR effectively shutting it off.
