Need the 10 crystal layout on the top side of a Kris 23+ cb tube radio
danmcclain
Dec 11, 2020
1,229
758
123
75
I've looked everywhere even Sams does not show the order of the 10 crystals behind the channel selector. I need the order of M4 thru M13. Help please. Thanks.... Dan
Not sure if this what you mean by "order of M4 thru 13", but I'm giving it a shot.
M4 - 14.970 MHz
M5 - 14.960 MHz
M6 - 14.950 MHz
M7 - 14.990 MHz
M8 - 23.540 MHz
M9 - 23.290 MHz
M10 - 23.340 MHz
M11 - 23.390 MHz
M12 - 23.440 MHz
M13 - 23.490 MHz
That's off Sam's CB #45, (thanks NZ8N) page 78. Had to use a magnifying glass to read the numbers. Apologies if that's not what you wanted or if I got any wrong, but at least you know where to look to check my work.
Reactions: NZ8N
M4 - 14.970 MHz
M5 - 14.960 MHz
M6 - 14.950 MHz
M7 - 14.990 MHz
M8 - 23.540 MHz
M9 - 23.290 MHz
M10 - 23.340 MHz
M11 - 23.390 MHz
M12 - 23.440 MHz
M13 - 23.490 MHz
Thank you TM86 for the reply. What I need is the order that they are installed, I know that M4 is in the number 7 slot, need to know what slots the other are in. They don't seem to be in numerical order...
I have Sams CB #45, but the crystals are covered with shrink wrap, can't tell where each crystal goes....
Dan, My pcb is marked 1-10. Did you ever figure out what crystal is in what spot. Looks like the 4 middle ones are the 14mhz crystals. any help would be appreciated. mrmeter@juno.com
Just a heads up, you should never post your current email address typed out like the way you did. Better to private message it.
    boog351 has left the room.
