Turner CS-1 schematic needed.
  • Thread starter Thread starter Hollywood
  • Start date Start date
H
Hollywood
Guest
I finally tracked down a good example of the Turner CS-1 (custom special) but it has been rewired with a non-turner color coded mic wire. If anyone has the schematic or wiring diagram for this mic I could sure use a copy of it.
Base:
President Lincoln,KLV 550
Mobile:Magnum 357</p>
Base:
Most generic mic wires use yellew instead of white . White In place of yellow .. Hopi g the installer followed that rule .. The turner is close to D104 wiring code reverseing red n blue .I other words if yiu normally put plue and shield together . Turner puts red and shield.. From what I see . If they rewired it like a D104 the switching would have from the bottom black. Blue red..
Normal turner wire to the switching black red blue
Hope this helps. Schematic is simular to a us 3b Depending on age
I have 3 ca-1 mics the amps are all slightly different from each other .
Here is what I have. Seems to be missing part of the right hand column, but the schematic is there.
Hope it helps.
Oops. I didn't see Xracerx13 had posted a link. Sorry bout that.
Reactions: TM86
    boog351 has left the room.
