D104/TUG8 wiring for Kenwood TS-120S?
KC8MWG
New Member
Oct 18, 2023
4
2
3
55
I have a D-104 mic on a T-UG8 amplified base that I want to use with my Kenwood TS-120S transceiver. How do I need to wire the plug so that it will work correctly with my radio?
Not sure about the wiring but if the 120S is anything like my 140S you will probably need to put an attenuating resistor in the mics audio output line. I use a Turner CS-1 on my Kenwood TS-140S and without the resistor the output from the mic was too much for the radio even with the mic gains barely cracked open.
Reactions: midnight special
