Is this a radio that can be fairly simply converted to cover 11m and if so what is its converted range and finally is it worth bothering.
Thanks in advance to the elmers.
Yes . 1 wire. It will go a little below 1 up to 28mhzIs this a radio that can be fairly simply converted to cover 11m and if so what is its converted range and finally is it worth bothering.
No AM. But one of the best SSB radios. I do have a link to a small board you can install to get AM. But I wouldn't. If you want AM get an AM rig.That sounds fairly complex. I believe I might just be able to manage that!
(Seriously didn't think it would be THAT simple) just one issue I didn't forsee.... this is SSB only isn't it, no AM?
Incoming Region Produces X3 Solar Flare |
May 15, 2024 @ 14:55 UTC |
Another major solar flare, but this time from an active region just beginning to turn into view off the east limb. It is possible that the group responsible is old AR 3654 from the previous rotation. The latest flare, an X2.99 event just peaked at 14:38 UTC (May 15). Stay tuned |
