Source for LED light ring for controls (aka nitro knobs)
Found a smaller ring, RGB 8-LED, 32mm (1.26in) in diameter. Although not cheap @ $7.50
https://acrobotic.com/collections/neopixel-compatible-rgb-leds/products/led-8
Darn close, looks like their diameter though, can pose a clearance issue to the next control - so the shaft may be ok for insert, the diameter of the outer ring may be the overlap.
You might find a LED light bulb useful. It provides a thicker light than LED strip light and can also be controlled from your phone via Wi-Fi. It’s a great device if you want to have more control over the lighting in your house and adjust it to your mood.
I have used these ( link removed by Moderator) for quite some time now, and they’ve proven to be a good choice. These LED light bulbs can shine any color you want, and you can also choose the brightness, which is really helpful when you have trouble sleeping in the dark and need some dim light at night.
I have used these (link removed by Moderator) for quite some time now, and they’ve proven to be a good choice. These LED light bulbs can shine any color you want, and you can also choose the brightness, which is really helpful when you have trouble sleeping in the dark and need some dim light at night.
I think you're on a whole other trip there buddy, not at all what is even being discussed in here.
Thanks for the info, next time we need to change the bulb in the employee bathroom we will jump on that.
The big red spam alert button is blinking , let me go check that.
Hmmmm
Yep
