Found it thank you.. Tommorows little project ..If you just go through this thread you will find everything you need to know.
Removing limiters is never a good idea. It does in fact turn a radio into a splatter box. You go ahead and believe what you need to so you can feel right. Any tech worth a darn can get the Ronald to sound good without cutting it up. Nuff said.Removing modulation limiters do not always distort every radio theyre removed from somtimes the removal brings a radio to life like the president ronald
Not looking into remove limiters buy just open up the audio na little more.. I'm using a Mic with adjustable compression.. No spatter box's. Just want decent loud clean but not over driven audio .. Never had problem Comunicating local or skip weather in US the US or Australia .. Never ran.power either..Removing limiters is never a good idea. It does in fact turn a radio into a splatter box. You go ahead and believe what you need to so you can feel right. Any tech worth a darn can get the Ronald to sound good without cutting it up. Nuff said.
Did you ever figure out what W3 was for ?Here's a picture of the adjustment pots. I wonder what W3 does. Anyone know?
My first handheld was an alinco DJ-560 and then a 580. The blue wire was magic.No no! Cut the little blue... oh wait, that's for the Alinco. Sorry.
Most modulation limiters prevent distortion. However, the one in the SR-94HPC simply prevents good performance. After reading people rave about this radio "having the strong AM audio Stryker is known for", I bought one. What a disappointment. It has the strongest modulation limiter is more like it.
This lack of strong modulation was not acceptable so I looked around for a schematic to no avail. When that didn't work I pulled the board and tried tracing the circuit from the mic input looking for the attenuation transistor. This board may be three layers because lots of traces disappear from the top of the board to the bottom. Like connections must be happening in the middle.
When that failed, out came the scope to trace the audio from transistor to transistor. Luckily, the desired one is on the top of the board. On the extreme front edge of of the board to the right of the white ribbon cable is a transistor. Two legs face the front edge of the board while one faces the rear. It's the leg on the right front edge of the board we are concerned with.
Solder a 470 ohm resistor to the pin on the bottom, right side of the transistor and ground the other side of the resistor. You could use the screw in the right front corner of the board to ground this side of the resistor. This loads the drive triggering the transistor to conduct and was the safest way I could find to increase the range of both AMC controls without defeating the AMC. It will distort if defeated.
Now the radio screams like 45 watts PEP should. Plenty of range on the controls so they can be set on the scope without distortion. If someone wants to post a detailed picture of this area of the board, I'll point out the location of this transistor a bit better. You should remove the ribbon cable and front panel when installing this resistor otherwise the soldering iron may burn both.
the FM power at "40w" i believe. do not recommend setting it that highAnyone figure out what the W3 pot is for ????
i did the resistor mod and it works...............but now every now and then i power up the radio and the screen is white...............have to to disconnect the 12v line and it fixes itself.i have not done the resistor addition, but i get respectable swing from 10W and I set the low power to 3W for now, get around 12 mfj watts from it. my question is if anyone got in there and did something to sample the audio and manipulate the audio drive to full from a low carrier to forward-drive a biased pillbox.
How has the amc mod held up? Wanting to try this.Most modulation limiters prevent distortion. However, the one in the SR-94HPC simply prevents good performance. After reading people rave about this radio "having the strong AM audio Stryker is known for", I bought one. What a disappointment. It has the strongest modulation limiter is more like it.
FM HI powerDid you ever figure out what W3 was for ?
