Isn't she pretty
ShadowDelaware
Well-Known Member
Jun 20, 2023
219
161
53
47
South jersey, North Delaware
udxcbradio.com
Brand new from August of 1976 Midland Model 13-882c. I dig the original decal and how the paperwork states "printed in Japan"
That "Midland Convoy" picture on the box is just screaming 1976 at the top of it's lungs LOL! Enlarged it would make a great radio room poster...........
At first I thought you had put blue LED's in the radio, but it's just the way the photos are for some reason. Phew! I'm so NOT a fan of blue LED's.......bleccch !
I just need to find someone local.
Do it yourself ! That circuit with the PLL02A chip is a great one to learn on ! The conversion for uppers on that radio only involves a couple switches, a couple of diodes and resistors, and an ability to solder.
Only one small problem......... the 02A chip can give frequencies up into 28 MHz, but you've got an AM only radio there and above 26.355 is ALL sideband channels, so even though the radio will go there, it's not especially useful seeing as it's only AM!
You will however gain channels 24 to 35 so there's that. Unfortunately, the 02A circuit will not go below channel 1, so the AM freqs. below that can't be reached by that radio at all.......
You could get all those lower frequencies if you can find an old Expo kit for the 02A chip, which involves adding a couple mixer crystals.
That makes sense and now I understand why a few of the old 23 channel radios I looked at had only 12 extras above 23.
The 02A will give you lows all the way down to 26.645Mhz with no missing frequencies in 10Kc steps, provided that you also program the 10KC pin 15. No extra mixing crystals are needed. In my experience it will go down even lower, but radical re-tuning is required that would also affect the normal channels. The same goes for any mod to obtain all the regular 40 Ch frequencies. Programming all depends how the circuit board and channel selector access the PLL. There are different versions (two crystal and three crystal), but rest assured the 02A is totally capable. Your 13-882C is an early three crystal radio. There’s even a 5Kc pin available, but I never messed with that pin. Programing is all done by isolating some pins, cuts in various traces, and by adding a few resistors. Sacrificing one or two switches on the front panel, or adding a dedicated switch somewhere else. It's all part of the job and what each individual wants. I converted a number of these Midland 02A Cybernets. Not so much to obtain the normal 40, but for frequencies down to 26.805Mhz. I once knew a group that used 26.865Mhz. As chance would have it, that frequency landed on Ch19, so going between the two frequencies was controlled by a single switch. Those guys loved that feature in their mobile.
Back in the bad old days of 23-channel CB radios, it was common for a radio with poor alignment to have an internal feedback squeal on the transmit signal.
Reducing the drive level to the driver transistor would cause this, often because someone had tried to "tweak" the band pass filter that follows the transmitter's mixer circuit. Most radios used three slug-tuned resonant circuits in a string between the transmitter's mixer stage and the first low-level transmit amplifier stage.
Simply turning one of those three slugs too far from its resonant peak would initiate this squeal on the transmit audio. Peaking all three of them for a proper 3.5 to 4-Watt carrier would stop it.
Had an unpleasant experience installing the ubiquitous TIP120 variable-carrier circuit in a Johnson 250 23-channel base radio. It uses the same circuit board as the 123A mobile CB.
Long story short, we ended up boosting the size of more than one filter capacitor and setting the minimum carrier level to a Watt and a half, if memory serves. Even after that much effort it would squeal with the carrier around a Watt or less.
40-channel AM-only CB radios don't seem to have this bad habit. Never have figured out why.
That particular Midland radio might work just fine with a carrier control circuit added to the radio's driver transistor. Haven't tried that trick on that model.
Might work just fine, might not.
Back in the day we thought we were pretty clever, placing a 100uf electrolytic cap in parallel with R131, a 10-ohm resistor in series with the driver transistor's collector circuit. This would improve the radio's peak modulated power without changing the carrier level.
A typical TIP120 carrier control would go in place of R131. Seems to me I posted a schematic of the circuit we use, some time in the last 15 years or so. Not sure quite what search term would allow drilling down a search for that post.
That was the best C.W. McCall logo pic I’ve seen. I agree, that one needed to be saved and enhanced for future use as a poster or smaller accent in an old school shack. That logo was placed on a number of different Midland models during that time period. I decided to delete the reference to any particular model for that reason.
