President Bill 2 FCC "Boost"
Tim Chambers
40
92
28
60
This will dramatically improve the carrier swing and modulation of this great micro CB.
You must be VERY careful if you do this modification as you are going to be soldering a through hole component from the center leg of the AM regulator to the anode of the SMD diode, as pictured.
You MUST use a fine tipped soldering iron for this mod.
As with all modifications, this is for experimental purposes.
Solder the cathode end of a 1n914 diode to the center leg of the AM regulator and the anode of the 1n914 to the anode side of the SMT diode.
Be very mindful of the time you have your soldering iron on the SMT diode or you will destroy it.
To access the service menu, you must key the mic and hold in the AM/FM button and EMR buttons while turning the radio on. PL adjusts the dead key. Leave FM alone!
AL adjusts the modulation level. The higher the number, the lower the modulation. 50 is the highest setting. Do yourself a favor and don't mess with anything else in the service menu.
Enjoy this little rascal!
Your mods are always very appreciated sir. You don't have to share but you do and that's great.
Just curious but what did the before and after readings look like in comparison?
Just acquired a president Bill 2 fcc opened up the case no white wire no jumpers all I was able. To do was bring the power up ro 3.8 watts and increase the audio slightly to about 60 % with stock or power mic does anyone know if there a limiter mod for this version? I can live with the wattage but needs more audio drive plan on putting a small amp inline for the mobile..
Thank you
Thank you
Just saw this diode mod will this work on the early ver of Bill 2.. No jumpers or while to cut on this board
Hi OK Soni did the diode mod helped greatly with the audio ran a solder bridge a gross where the jumper would be and got good swing .. B4 bridging was dead keying 3.5 even maxing in the firmware after the bridge now peaking 18 to 20 with 100% clean strong audio looks great non the scope and spectrum anaizer.. ..
