WHAT RADIO ARE YOU USING FOR YOUR GMRS BASE?
Rick330man
WDX 404
Mar 16, 2013
1,211
2,315
273
Florida Keys
I go back and forth between a Midland 575MXT and a Retevis RA 86. As a base, I don't need a zillion repeater pairings. I have five (5) Florida Keys repeaters programmed, two (2) Miami ones and one (1) in Naples. The 50 watts on the Midland is a big plus, but the Retevis is more user friendly. The latter is important since I want my wife and boys and to be comfortable. A radio that is easy to use fits the bill. I need a few more repeater pairings in the mobile and have found the Radioddity DB-20G to be perfect for my needs.
What are the rest of you using for your GMRS base(s)?
Reactions: Brother DXer
I use a Midland MXT115 as a base and unfortunately there are no repeaters in my area. I bought a copper J pole antenna a while back from ebunk, but have not put it up yet. I also have a few UV5r radios that we use between houses in the neighborhood.
None! I don't think there are GMRS repeaters in Canada, at least not in BC. If I climb the highest hill around here I can hear a repeater down in Mount Vernon WA which is almost 200 miles south of me. That appears to be the closest GMRS repeater to my QTH !
I have GMRS frequencies in my Baofeng but all I ever hear on them is kids playing radio and a few small time business users. Everybody else is on the LADD channels.
Reactions: FlyBoy50
We.ve been using BAOFENG UV5R hand helds on our farm's base, both mobiles, and one for each of our workers. All bought in 2009. 9 total. The 5 used by our workers are pretty shabby looking, because life isn't harder on a radio then when it's hanging from a Colombian farm worker's belt all day. The other 3 (and the spare) look new. The base radio in our farmhouse (which is the highest point on the property) uses a Larsen BSA-450 antenna on a 40' pole. It easily covers all of our 22 hectares (54 acre) farm. Except for batteries, never replaced anything. All 9 rigs still functioning 100%. For 20 bucks each, best bang for the buck.
I use the Midland with a Nagoya NMO200C antenna on a 45 ft. pole It gets out pretty well, I have alot of hills to block it but 20-30 miles it works good
Reactions: BC Coyote
Are you using UV5R for the GMRS ? I unlocked mine for GMRS but haven't loaded in the channels because I'm nervous about making a mistake that I won't know how to reverse. But I have to get it done so I can explore GMRS and find if it is worth spending more money on that phase of the radio hobby. Much to learn yet !
Yes, the uv5r works great for GMRS. I use the programming software called "Chirp" which works for most amateur radios. It is free to download, though I don't remember where I got it. You could also just punch in the frequency if you just wanted to try it out.
Reactions: FlyBoy50
I didn't buy the cheapest UV5R, I spent about $75 bucks for the 8watt model with software, large & small battery, 2 antennas, and bought 2 different GMRS antennas. And I have the cable to hook it to the computer also. I guess I have to install the 50 watt channels because mine does 8 watts but I'm confused with the old & the new FRS/GMRS channels because of the FCC changing that Part 95 BS so was kind of waiting until I took a trip to North Carolina to visit my Ham buddy. And the privacy tones is another can of worms that I would probably try to run with out. I just learned how to shut off the privacy tones in my blister pack cobra that's probably why I heard that Conversation yesterday. I'm just a old CBer trying to get up to Speed ! LOL
PS. We always used the blister pack radios just in hunting season.
While I'm at it before I start the research, What is the most commonly use radio for a GMRS base station. I was thinking on one of the better Midland mobiles but only because I've seen them advertise mostly. But then again that is a uneducated guess!
I found out that the Midland 115 will not operate on the low power FRS channels 8 through 14. It has no provision to reduce power, so they just took them out. I don't know if the other Midland mobile radios are like that or not. I have a Btech 50 watt radio in my truck that will end up being my base.
I have also been looking at this one:
Reactions: FlyBoy50
If I can ever get my friend with a PC laptop to come over and try the other software that Radioddity sent me, I would be using my TYT 9800. Antenna is the monster 17' Diamond X510 VHF/UHF that is very broadbanded on uhf. Low SWR thru the 470's
Will be using a retevis mobile as a base.
It's here but not set up as waiting to install base antenna and coax etc when antenna arrives.
