Stabilizing Frequency - what do you do?
Lkaskel
Well-Known Member
Aug 4, 2017
544
441
Hey Everyone,
I guess the 1st thing to do is explain the case study. I have a 198? President Jackson export radio with the PB 042 board in it (see attached pic). I have completed a full recap. removed the glue and aligned. The only mod is an unlocked clarifier and the rest of the radio is set to spec. The truth is, it's a great receiving radio and I get nothing but great reports on the audio (mainly SSB) using a Turner +2 mic. The radio never gets turned off only down (0 volume). It's been running for about 3 weeks now. As the temprature has dropped here in Maryland the overall temp in the house may drop only a few degrees. The interesting thing is, every few days the radio is raising in frequency. When the radio was aligned I think the house was about 72 degrees and it is currently 67. It's currently 250Hz high on all bands. I am assuming that this is due to the temprature.
What do you do to stabilize the frequency in radios like this? Would you have any other thoughts as to why the frequency would rise like this other than temprature?
Some radios are more prone to drift than others. Generally processor controlled radios are more stable then say a Galaxy sailboat on SSB. You might do some research on a TCXO circuit and see if it could be added to your radio. Sometimes clarifier mods have a negative effect on frequency stabilization as well. Good luck, nice old school radio.
Turn up the thermostat and check again tomorrow.
What frequency changed? If all modes moved the same, it suggests the oscillator that is drifting is common to all modes. Being you have already done an alignment, I assume you can figure out which oscillator is the culprit.
Random thoughts follow...
Do new electrolytic capacitors need time to reform? If they sat for a few years at the factory, their characteristics may have changed in the first week of use. If a cap is used to stabilize a tuning voltage, maybe that slight change in leakage resistance cause it to shift.
Maybe there is a bad trim cap or pot that changed value from being slightly jarred around. Had that happen in my washington. Alignment went great, radio worked fine, a few days later, I was 400Hz off. Moving the radio on the desk was enough to make it abruptly change frequency. Lightly tapping on the trim cap sent my frequency all over the place, problem found! A wore spot in the clarifier pot can do this too.
What about wax? Every radio I ever had with wax around the oscillators was rock solid. Maybe that is enough?
I can't remember where I heard this, but I remember something about physical shocks causing the drift characteristics in a crystal to "reset". I wish I had dug further into that when I came across it because I know nothing more about the subject. I have no first hand observations of this happening, but if it is true, perhaps giving the crystals a little tap before alignment might reduce the odds of it being off frequency later down the road if the radio does get bumped. I'm not advocating hitting your radio with a hammer, just set it down hard a couple times before alignment. It's going to happen eventually.
Only solution is a crystal heater kit. Wire it to operate when radio is turned off and keep power supply on.
Here is a followup to this frequency issue/case study. Two days ago I turned the heat on in my office and have maintained a room temprature of 72 degrees. I waited 2 days to allow the radio to settle. I am unsure how necessary that is but it is a good reference. The radio is now 100Hz high so there is a difference of 150Hz give or take. I'm going to maintain this temp for a few more days to see if the frequency changes. I may try one of those crystal heaters to see what type of outcome they bring. In the end, the radio works great and it's just interesting to see how different options affect a radios performance.
More to come....
Reactions: brandon7861
Hey Brandon,
All 3 modes were affected. It will be interesting to see if X1 (10.240MHz) or X2 (14.55MHz) is causing this. The alignment went well so I do not believe that any of the VR's or trimmer caps are at fault but....that is a possibility.
Hey Brandon,
If it is the PLL divider reference, I would expect an incrementally different error in frequency on each channel.
Reactions: Cable Guy
