New Anytone 6666
DCC
New Member
Sep 10, 2024
I just got an Anytone 6666 and what to put it in my car (2013 ford escape). Can I use the powerpoint to plug it in or hook directly to the battery? The powerpoint is on a 20A circuit.
A 20A circuit will be plenty. Of course, it’s always preferable to go to the battery direct to limit the length of the run for max voltage and to limit noise pickup.
If the socket is rated for 20A, it will have 12 AWG wires. If not, then Ford is asking for a lawsuit when someone burns up their car. A good way to tell for sure is by looking up the amperage rating for the fuse in the aux socket circuit. 20A or higher and you're good to go.
FWIW, my 6666 pro hits 12A on peaks on SSB at the full 100W output and 10A full output on FM.
For a permanent installation, running wires direct to the battery is always the best way for lots of reasons regardless of what the socket says it'll handle. For a temporary installation though, you'll be fine.
I have a anytone at-6666 or quad 6 an all out great transceiver as all anytones are I think but the carrier output power with the rf power turned all the way down it's dead key is about 15 watts average.
Can I turn this carrier down by adjusting AM PL on the inside of the radio ? And will the AM PL only affect the output power when it's turned down while the AM PH adjust the output when the rf power is turned all the way up ?.
I know on the quad 5 plus the AM power high and power low adjustments are in the service menu and that's how those adjustments affected the output watts and hope it's the same with the quad 6 at-6666.
Please and thank you
Just to clarify I'm talking about the original q6 not the pro as I own that one too.
The Am Pl is AM power low so it will adjust the low carrier. Adjust and see what you end up with. I can't remember 100% but you might have to slightly adjust high if it brings it down some. In my experience they came stock with the high power turned a little too high for my liking so I turned mine down to 10 watts high. The radio has plenty of swing to do plenty so they've worked well for me.
That radio should have an RF power control right there on the front of the radio. Top left I think.
I understand, sorry I did not see it was your post until after I typed. Thought it was a new member with new radio.
  • @ Spanish:
    Where do i upload schematics
  • @ Catalyst 122:
