RCI 69 BASE PLUS peak n tune
Ain't none.
And no schematic diagram.
All of them we've seen so far don't need alignment. Starting point for alignment instructions would be the schematic IMHO.
Not sure who you would have to blackmail to get a hold of that.
Reactions: Copycat32
Hi all.. I just picked up a rci 69 Base plus plus
Found the 11 meter mod..
Trying to fund peak n tune adjustment n procedure.
Any one have any info
Thank You
Did you receive the current Owner's Manual for manual for the Plus Plus? My Plus Plus came with the manual for the "Plus" and the specs are not the same because the RF Power output on the Plus Plus is more than the Plus. The fans are sort of noisy when the radio is at an idle.
Thank You
FYI
I use a DELTA M2 microphone. Tone set @ #5 and Modulation set @ 5 and Mic Gain on the radio set @ 12 o'clock. Obviously, you need a 6 to 4 pin mic plug adapter. I favor the Delta M2 because a battery is not required. Upper and Lower sideband transmit and receive were "way-out" of specs from the factory.
Got the socalled manual.. Don't tell you much.. Yes the fans are noisey.. OK during receiving but the Mic picks them up very easily.. Considering changing them for quiet computer grade muffin fans..
So other then the 69 Base plus ++ only showing 80 watts mid band witch I can live with at low power below 10 watts the TX audio gets extremely fusy staticly.. Anyone have this issue?
Got the so-called manual. Don't tell you much. Yes, the fans are noisy.. OK during receiving but the Mic picks them up very easily. Considering changing them for quiet computer grade muffin fans.
How effective can the dual fans be with the 3-inch-high aluminum plate blocking the path for heat to escape? There is a heat sink behind the finals and the power supply has a fan. I don't get it. The fans are always on.
I'm considering liquid cooling mounting then heating with tubes to the back of the radio heatsink have the pump outside the radio with cooling plate instead of fans then it's only a s mall pump witch is much quiter then the 2 or even 1 fan running . I tried with filtering the fan frequency but it garbled my audio.. Got the same problem with the ac running 2 in the background. Luckily Im. On mostly at night don't need the ac.. Lol
