D&A Phantom Transformer wiring color code.
Jimbo165
260
45
75
Southeastern Michigan
I am looking how to identify the wiring coming out of a D&A Phantom transformer. I am going to try and use this transformer in a Apollo 500 amp that I have that fried transformer. I see 2 reds, 2 greens ,grey, and others. Thanks
Should have two reds and one red with a yellow stripe. The red wires are the 630 Volt secondary, the striped wire is the center tap.
The two green wires should also include a third one with a yellow stripe. This is a 12.6-Volt secondary, the striped wire the center tap.
The two remaining gray wires should be the 120-Volt primary.
The Apollo probably used a transformer with less than half the voltage on the HV secondary as the D&A unit. Best I remember Apollo used a full-wave voltage doubler with a transformer secondary under 300 Volts. Had two 450-Volt filter caps in series.
The D&A transformer works best with a full-wave bridge rectifier, not a doubler. To boot, it will produce too much DC voltage for just two 450-Volt filter caps in series. You'll need either three 350-Volt caps like D&A used, or three of the easier-to-find 450-Volt caps. Just be sure to put a bleeder resistor across each cap. We use 220k, but anything between 180k and 330k works okay, just so each cap in the string has the same resistance value across it.
The D&A isn't a direct drop-in substitute but with a little adaptation it should hold up better than the factory transformers. They were just too small.
Thank you nomadradio. i am going to give it a try. Amp does not work now . I may ask more questions later.
One D&A Phantom transformer is rated about 500 watts. It would be pushed very hard in the Apollo amp but not likely fail. Peak HV voltage would drop to 800 volts vs 850 volts in a D&A amp..
With a little adaptation....
I used a pair of phantom transformers in a Heathkit Warrior 4x 811 tubes. Gutted the choke input and just used caps for the filters. Thing worked great until the kid (Joe Dirt) out of Banks OR decided he needed more and installed some 572b tubes.
How did da wire the supply? Was it a full wave rectifier? Was it a doubler?
