Robyn DG-30
ClaimJumper
86
29
28
62
Does anybody have or know where I can get a pic of a robin dg30.? Inside near the power Inlet. This was where the power cables came in . 20241101_172305.jpg
This is the lower left corner of the rig. The part I'm interested in.20241101_172939.jpg
This came out of that lower left corner of the PC board. The coil you see in the board and this one went to positive and negative terminals on the jacked up power Inlet housing. I just want to clean it up and put it back to stock. Might have to just run cables through the chassis. Sure would be nice to see what a stock one looks like.
Okay the Robyn is up and running.
The only thing I'm going to do to it now is what Shummy did to his with the three pin power plug. I'm assuming that matches straight up to the holes that are already in the chassis?
Okay the Robyn is up and running. The only thing I'm going to do to it now is what Shummy did to his with the three pin power plug. I'm assuming that matches straight up to the holes that are already in the chassis?
I believe you may have to do a little fine tuning with the Dremel tool. Those Uniden 3pin jacks are pretty big compared to the Robyn 2 pin stock jack.
Reactions: ClaimJumper
Okay. Well if I can't find the stock Jack, which I doubt I can, that's what I'll do. The stock one that was in there was just a melted blob of plastic.
Well the Robyn is done now. Thanks for your help Shummy! All the schematics and tips along the way. I did the three pin power cable jack. Came out decent, I got it a little crooked though.
I cleaned it up a little bit with a stone in the Dremel . I drilled the other hole for the mounting bolt, and had to slightly cut the insulator on the PA Jack in order to make the three pin fit. Not too difficult though.
Reactions: AudioShockwav
