What have I done today
This is a little one that is handy for portable work and camping. I've even run it on my porch with a extension cord to run my computer as temporary. LOL
That is a Dandy & should GET-ER-DONE and looks like electric start like mine. But it will be a heavy sucker so find it a permanent home. ENJOY
Yes, it's not going to be moved and the electronic start is an upgrade from the Generac and I DO like this option. Back when I bought the first generator I also bought this outdoor storage compartment and made a few modifications by installing several vents and an exhaust coming out of the container. It looks old and worn now but it still does the job.
As the favorite question in this forum goes. Today I installed 50 amp generator inlet box and interlock kit to my panel and verify I say unto you with my two dual fuel parallel kit if needed 4600 watt each generators I shall have power throughout all of my lands (sans 220 because these generators I also use for power on pop up camper trips are 110 capable only) but I have wired with being future proof in mind vs cheaping out on a 30 amp box and wire should I choose to get a godzilla generator that does do 220 at a later time.
You're doing ALL the good with this system!! This is great, and will save you a lot of heartache and frustration.
Excellent, my friend!!
73's
Reactions: lonestarbandit
Yeah that will work as long as you have a fresh air intake and a way to expel the exhaust. I have the same shed behind my garage that I store garden tools in.
