Antenna Splitter?
Backwoods40
New Member
Oct 28, 2024
9
15
3
53
Can something like this be used to run a single antenna to both CB and SDR?
You can get a switch that switches between sdr on receive and transmitter when keyed.
There used to be a guy on eBay that made an automatic switch box, all radios are connected to antenna on receive. Then when one was keyed, it switched the others to ground. He quit making them because they didn't quite switch fast enough for some radios.
I am surprised nobody has made a little adapter that goes between the mic and radio that picks up the switching signal there and adds an unnoticeable amount of delay to the radio ptt
Google search SDR TX RX Switch and you'll get plenty if hits for these boxes.
This is what you'll need so your SDR and Radio can share the same antenna! Check some reviews if possible to see what other users said about all of these models.
I have an older one made by ELAD which works well. Like many of the ones I see today are both RF sensing and also use a PTT line to protect the SDR during TX.
I prefer a PTT line but I have used just RF sensing and it works just as good.
Here's some pics below of a typical SDR-TX/RX box to give an idea how to hook one up. Many of them have SMA or BNC connectors for the SDR RX line so you need an adapter. I've used this one for my Icom-7000 which was a bit difficult to add an RF tap so I just used the antenna and RF in/outs for my SDR and relied on RF sensing. These one's may still be available online.
Using the MFJ box pictured below as a typical example how to hook one up,
Connect SDR antenna out to SDR REC in
Connect Radio antenna out to XCVR in
Connect Antenna to ANT jack
Connect PTT to Control (optional)
Screenshot 2024-12-04 at 15-57-35 Microsoft Word - MFJ-1708B-SDR Manual.doc - MFJ-1708B-SDR_MF...png
The AUX line on the MFJ models is a RX mute line (why?) and the DELAY is a screw adjustment to determine how fast or slow you want the RX to come on after TX.
First pic has S0-239 for the SDR input and second pic has a SMA connector for an SDR, otherwise both the same.
It's fine to use that for two receivers, but if either unit is used to transmit the magic smoke will be released from the other unit (as 999 said above).
