11 Meter CB antenna plans needed
Retrodata1
New Member
Hi everyone, Is there a person who has a detailed construction plan for a 11 meter band arial , I am looking at building a cb radio home base antennae for my workshop unit, 1/2 wave , 5/8 anything will do. Please can anyone send me plans as I have searched and so far nothing. I currently have a 5/8 on my roof and was thinking of reverse engineering it however if I can build one from a plan it would be great, thanks GARY
You can learn from building. You should try it sometime, then come back here and share some wisdom.
Amen to that.
or
You can buy junk cheaper than homebrew and then replace it and replace it and replace it......................
Reactions: TM86
A quick Google of "homebrew 5/8 wave CB antenna" resulted in a half-dozen web site and YouTube hits. The info is out there.
7 3
This is a thread from 2010, a homemade ground plane building contest.
The Beer can antenna is on page 4
Much Thanks to Homerbb who dug that thread up for me after searching hours for it.
Go look at the antenna he made out of chicken wire, plywood and PVC on the first page.
Reactions: TM86
What a cool idea! I had a friend way back when who built a 1/4 wave GP out of rusty barbed wire from an old fence, a long pole from the bush and some discarded 75 ohm TV coax LOL! Just to prove it could be done.......
It worked, but I don't remember how well!
Reactions: AudioShockwav
