SignaLink connections with Kenwood TS-930S
MJGRX
New Member
Dec 12, 2024
I am looking for a connection diagram for a Kenwood TS-930S and a Tigertronics Signalink. I have not found any information as to how to do this or if it can work? I have seen interface cables but nothing that says it works with the TS-930. thanks in advance for any help.
Found this link.
Signalink wiring for Kenwood Mobile/Base
As long as you got the cable, it should work for yours 930S. Wire the signalink as it shows on the website.
I do see it listed as the 930, but basically the same radio.
Greetings to all - I just came across this Forum and look forward to chatting with you all.
Concerning the SignaLink issue - you should note that TigerTronics produces pre-made jumper blocks for all different radios. They are inexpensive and much simpler than setting jumpers manually. Additionally they allow a lot of flexibility to switch the box from radio to radio without messing with the jumper wires.
73 and good luck! See you on the digital bands!
Reactions: doffo
The Signalink is a sound card interface. It will work with pretty much anything. audio in/out and PTT.
    boog351 has left the room.
