Yes I have CB-11 that contains info on the HB-600. Do you just alignment and tuning or the whole section on this radio?Let me check and get back to you... Dan
Yes I have CB-11 which contains info on the HB-600. Do want just tune and alignment info or the whole thing for that radio? DanLet me check and get back to you... Dan
Dan - Thank you!! I'll probably need the whole thing as I have no modulation (have a carrier) and no receiveYes I have CB-11 which contains info on the HB-600. Do want just tune and alignment info or the whole thing for that radio? Dan
Copy that... Give me some time to scan it... DanDan - Thank you!! I'll probably need the whole thing as I have no modulation (have a carrier) and no receive
Regards,
Justin B.
Sorry for the delay, had a rough night. Here is the info you requested... DanCopy that... Give me some time to scan it... Dan
Dan - Thank you for getting this to me, I appreciate it! Worked on the decrepit old beast today and it looks like it will be a long journey.Sorry for the delay, had a rough night. Here is the info you requested... Dan
It seems I am having a string of bad luck picking up old radios that I can't find manuals for - even on FleaBay! If you could help me out with a Realistic TRC-47 that would make my day!
73,
Justin B
Justin...Let me check and get back to you... DanDan - Thank you for getting this to me, I appreciate it! Worked on the decrepit old beast today and it looks like it will be a long journey.
73,
Justin B.
Justin, yes I have CB-61 which contains the TRC-47. Give me some time to scan it... DanJustin...Let me check and get back to you... Dan
Here you go Justin, the Sams section on the TRC-47... Enjoy... DanJustin, yes I have CB-61 which contains the TRC-47. Give me some time to scan it... Dan
Thank you, Dan! I have one more request and I will quit buying old radios for a while. It is a Lafayette HE-43C. I can't find much at all on the internet but I find it having an analog receive with crystal transmit interesting. I am thinking this radio might be a good candidate for replacing all of the crystals with an Arduino controlled 5351 module.Here you go Justin, the Sams section on the TRC-47... Enjoy... Dan
73,
Justin B.
73,
Justin B.
Sorry Justin, the HE-43C does not appear in the Sams CB Index... DanLet me check and get back to you... Dan
Are you still working on the HB-600? This is my enhanced version with a separate spliced together schematic.Dan - Thank you for getting this to me, I appreciate it! Worked on the decrepit old beast today and it looks like it will be a long journey.
73,
Justin B.
Sun - Good looking schematic and yes I'll probably be working on this for some time! I usually jump into the alignment and with this radio I get no tone from the speaker with the signal injected into L13, pin5 as directed by the book. If I inject after L14 I start getting a tone so I am wondering if the filter or L14 might be wonky.Are you still working on the HB-600? This is my enhanced version with a separate spliced together schematic.
I don’t know if you’re still looking for the SBE LCBS-8 Owners Manual? I have a scan of it if you need it.I have almost a complete set of Sams PhotoFacts for CB. If anyone needs info on a specific cb radio just like me know and I will see if I have that Volume. KEEP CB ALIVE!
