First ham base
So getting ready to take first dive into ham waters....... looking for some input as to good initial base, preferably one could grow into and a more old school type of unit. Don't need bells and whistles.
I have a fully restored IC-735 that I would like to sell. I will never recover the time invested in this radio, but it needs nothing now, and is very clean. It has the capability for computer control if you ever go there.
I am planning to be buried with the one I bought in 1989. I have many radios and still have a spot for my 735. PM if interested.
73,
SL
Reactions: Smokinone
Save your quarters and get an HF radio that has a built in USB sound card. You can grow into digital modes without buy any extra hardware. If you buy one without this feature you may be spending more money later. You will also find computer logging programs easier to use.
The receiver on any radio made in the last 10 years or so will be very good.
A Kenwood TS-590s (not the SG) can be found used for $600 or $700. Save a few dollars more and you can get an Icom 7300 or Yaesu FT-710 for about $900. You won't need another radio for many years.
Reactions: Hilltop
Nice old school radio. Keep in mind that radio could be as old as 1988. This means if it needs work finding someone to work on it will be hard,new parts impossible.
The 430s is even older, possibly as old as 1983. Same problem no new parts and very few techs will touch it.
There's a ham in Florida that does repair work on the 430 and 440. Once repaired and aligned he sells 'em usually just under $300 shipped. I bought a TS-850 from him that he did worked on/aligned, and it did well. I've seen his ads on QRZ once and awhile, but more often on QTH. He had a 430s a couple weeks ago for $295 that I almost pulled the trigger on, but my tremendous self-restraint + my wife looking over my shoulder held me back :sneaky:
Well, there's old school and really old school. In the later category, there's the Kenwood TS-520, 520s, 530s, 820, 820s, and 830. All solid-state except for the finals, which are tube. For someone just getting into the hobby, I'd only consider the ones with a built-in freq. display, like the 530/820/830.
Otherwise, for 1980s radios - Kenwood's TS-430S or TS-440s, perhaps the Yaesu FT-757GX II, or ICOM IC-735. It's not uncommon to find one that has been recently recapped and aligned. If you hang around (i.e. "HAUNT") the QRZ and QTH 4sale forums, you run across several of 'em each month.
There are too many other radios between these and the latest transceivers to list, so I'll just mention a couple:
  • Kenwood TS-50 (only pick ones that have been recently recapped)
  • ICOM IC-706MIIG
  • Kenwood TS-850
  • ICOM IC-737, 738, 736
The middle two radios above will fetch over $500, and that's where saving up a few extra bux to spend more can get you something like used Yaesu FT-710 Field, which would serve serve you well for years to come. I've seen these in the $700 - $800 price range.
Yaesu's FT-891 is no slouch either. No waterfall, but fully equipped to run mobile or base: New, $630. Used, $450-$550
Last but not least - The Dayton hamfest is approaching quickly (May). If you can't make it to that one, most of the large dealers (HRO, Gigaparts, DXengineering, etc.) will have several HF radios on sale via their website for that week or weekend that will most likely be the lowest price you'll see on a new radio this year.
I've forgotten plenty worth mentioning, but others will mention them. This was a quick "My .02 cents" opinion.
73,
SL
I also have an IC735. It has general coverage receive as well as the HAM. It has good audio in and out. As far as I know the trimmers were a source of a problem but I had them replaced a decade ago and haven't had any issues. No menus or any other things to try and remember. Just tune and talk. Stores some freq's. Has been a great rig.
Just my $.02
The new FT-891 is a multi-band and multi-mode portable transceiver with up to 100 Watts of stable high output power. Carefully and intelligently designed to fit into an Ultra Compact (6.1'' x 2.0'' x 8.6'') rugged case, the FT-
891 includes many popular features typically found only in larger-sized HF transceivers.
  • @ Spanish:
    Where do i upload schematics
