Elecraft K4 Remote operation...finally!
Ham Radio Nerd
Apr 14, 2002
9,327
2,026
383
This last weekend, I took a motorcycle trip with some friends up to Beatty, NV from Los Angeles. I took the Elecraft KX2 with the AX1 antenna for 17, 20, and 40 meters, as well as the AX2 cut for 10 meters. During my spare time in the morning, I made a few contacts on that setup with 10 watts, SSB. But I also brought my notebook computer to give the remote Elecraft K4 apps a try which just became available last week.
The long awaited VK4 software app from Elecraft has been delayed for years, with no delivery date in sight. BUT, in the last month, they finished up the K4 firmware to finally allow sending of audio TX and RX over ethernet and made the APIs available to third parties. Virtual K4 is now available for Apple users, but I'm a Windows guy. There are now two applications available for Windows, and I've given them both a try; most recently I purchased Win4K4Suite which has full remote support for the K4. I also configured the KPA1500 amp for remote control, as well.
Both the K4 and the KPA1500 have an ethernet port, but my setup is only WiFi at home, so I use this IOGear Ethernet to Wifi adapter. Both the K4 and KPA1500 amp remote settings support secure connections via passwords. Once everything is configured, it's amazing. You can operate from anywhere with a moderate internet connection to scratch a ham radio itch. Here's a pic of the PC connected back to the home station operating 10 meters:
I even configured Log4OM to connect remotely to the rig to capture the frequency, time, etc. for the log. What you don't see in the screen shot, is that you can digital modes such as FT8 just fine. Using the free VB-Audio Virtual Audio Cables, you can change the mic and speaker on both Win4KSuite and the digital app (such as WSJT-X) to stream the audio between the apps and operate digitally. It just works!
There is also an open-source app that is under development that has the basics working, but lacks the overall features of the rig - I will report on that in another post. But for now, this setup has opened up whole new possibilities for operating ham radio while travelling for business or pleasure.
Interesting setup and some good tips, I do a lot of remote operating myself so I would like to share my experiences and what I use.
First, I'm surprised that Elecraft previously didn't have a remote server software program for their radio's. I have the KAT500 tuner and I use that for both local and remote operating and I know the KPA500/1500 has that capability too.
When I do remote for ragchew with friends, I often use the Kenwood ARCP890 via the LAN connection which does work best and I have complete control over the radio because it's also has the complete radio settings menu and I get the band scope access too. The VOIP I use comes from Kenwoods ARVP server which is tapped from the USB connector on the radio. Unfortunately, Kenwood has a flaw using LAN for remote audio, it only works when the remote PC is connected to my home network.
For rotor control I use PstRotatorAz which is a great program and it has it's own remote server, selectable auto-tracking, and WX feature that lets you point a beam (or 90 degrees ) into the wind automatically based on either wind speed and/or gusts if you have a compatible WX station configured to it. This is great when not at home on windy days to help relieve undo stress on beam antennas. Many other great features are on this program too.
If I'm doing remote DXing I like to use HRD remote server so I can instantly log it. HRD has no audio server so I use the Kenwood ARVP.
If I see good DX on FT8, I found using TeamViewer works best for remote operating. This is because I can have all the same programs up and running just like if I was in the shack and see it all. I have WSJTx and JT-alert running along with HRD so this way all contacts get immediately auto-logged to HRD, QRZ, and Clublog then at the end of the session I upload to LOTW.
If you try Teamviewer for FT8, I found using any VOIP program you are using now over trying to get Teamviewer audio conference audio working. This isn't necessary if you don't mind not hearing any audio with FT8 but I'm used to hearing the RX tones and I have my radio's TX monitor on because I'm used to hearing the TX signal too and a separate VOIP lets me hear all of this.
If you need a free separate audio server program this one here works well.
Teamviewer is a program you should have on your shack and remote PC if you don't have already. This way you can fix any issues like turning server apps back on especially if your computer gets shut off. You should have your computer set to restart after power loss in the BIOS section or use a good UPS. Teamviewer now limits how many computers you can run on for free without buying a commercial license.
I can also just use Remote Hams free remote/client software which is a an Elecaft approved program which gives you a generic K3 radio to control on the main screen but also has side panels for easy and quick access for the KAT500 tuner, KPA amps and a few other brands also, and rotor controller programs.
I do use RemoteHams in the background if I'm using the Kenwood ARCP or HRD servers because unfortunately my HF amp has only local remote control and no server capability so this gives me amp access. I also use it for a friend in Pennsylvania when we do the RT66 OTA special event in September so he can use my station remotely and this makes it easy for him to access my radio, tuner, amp, and rotor.
Remote operating is a great way to run a shack when away and the technology now to do it is outstanding!
Good luck and have fun with your remote station!
Above my pay grade and mental capability but darn fascinating.
Thanks for sharing! :giggle:
Reactions: Crawdad
