I remove the antenna from the radio, put a couple inches of wire in the end of the SO-239 and then set a homemade "relay buzzer" next to it. The buzzer creates a bunch of RF "hash". You can then tweak L1 and L2 for minimum noise.L1 and L2 are peaked using a 23.5 MHz signal from the signal generator.
Of course, if you have all the correct gear to do it properly, by all means use the proper method. But if you don't the "buzzer" method works fine too......
