PC999 components
Tomsawier
New Member
Aug 16, 2025
5
34
Hello! Can anyone tell me the value of the L27 component (inductor) in the PC-999 (President Grant)?
I bought an incomplete PCB and want to replace it. Also, where is a good place to order parts for it? What is the name of the screw used for it?
Per the service manual bill of materials
BLBY-0209001 LB-209 113cn-6485z
same for L27 and L30
Using the 113cn-6385z designation, seems to also be in a Galaxy dx-979 (L25) ECIFT12013,
or L25 in a Galaxy dx2517,probably others. That's all I found so far.
Reactions: loosecannon
this is going to be a difficult part to track down.
you're not really going to find any listed value, but the coil you are looking for is an LB-209.
It is for the 16mhz local oscillator circuit, and tunes the LSB section.
it also happens to be the same coil as L30 in your radio, so if you have one of those, you can remove it and measure it, but again, that's not really how anyone would have it listed.
you might try Kenselectronics.com.
I have already looked on Barkett's site and didn't see one there.
there is something you can try, but i can't guarantee it will work.
Old galaxy exports used to also use a 16 mhz LO but not quite the same freqs as the grant DX.
so, the galaxy export part you can try is from the DX77HML:
or the one from the galaxy DX959 would be:
there is another coil that could work if the footprints of those others wont work found here:
i cant guarantee they will fit, or if they will work, but in the interest of saving on shipping, its probably worth it to just buy all three at once.
good luck!
Reactions: Cable Guy
All of the inductors in that area should at least have the same ferrite material, so I would grab any of them.
The difference between that can and the one next to it is that your can is for LSB and is pulling the crystal a little lower in frequency. Knowing that fact, you can expect it to have a turn or two more than the can next to it. The more inductance you have there, the more the crystal is pulled down.
If the crystal can't be set low enough, add turns. If it can't be set high enough, remove turns.
I got the value of the L27!
A CB pro technician desoldered one and measured it. Without the ferrite core, it’s 1.8–2 microhenries, with the ferrite core, it’s 5.7 microhenries.
Also, I’m missing the L17 coil, but it can be replaced as follows if no such coil is available.
Instead of the coil, use a 1.5 kOhm resistor, and replace C86 with a 100 pF capacitor.
I’m planning to use 2SC5200 transistors for the final stage (TR15-16). Do you have any practical experience regarding the surrounding components to aid my build? Also, any suggestions for extra protection or anything professionally recommended?
Do you know whether he measured the primary or the secondary of the coil?
some of these coils have both and only one side is used.
also, with the ferrite slug, the value will vary depending on it's position.
Even if you have all that right, there is more to a tuning coil than just its value in henrys.
that's why slugs have different permeabilities.
its also why these coils are never marked with a value, only a frequency.
as for L17, that coil has a very important job and should be peaked while using an oscilloscope.
hey, if it all works out then more power to you, but i have a feeling you are in for some disappointment.
Believe me, if I've learned anything, it's that it's better to trust others' experiences than to stubbornly cling to something.
An approximate value will be good enough as a reference, but I'll focus on the frequency.
I'll order a few, and then I'll adjust the coil turns until the frequency falls into place.
    boog351 has left the room.
