I have a deluxe and a super. The info on the deluxe is an easy find. The super not so easy. It looks very similar as a radio set but not the same at all. That said, maybe someone has a service manual and/or a operators manual for the real or newr super.
This is the deluxe. Often mistaken for the super. Note the clear knobs, the load and plate tuning, the antenna switch, and white meters. Transmitter is on top. Receiver is very similar to the super only that its hook up to the power from the transmitter runs through a round 12 prong plug. I have everything I need manual wise for these. Thanks to all.
This is the super. Similar but not exact. The transmitter does not have the plate and load and the knobs are black. Meters red and green. Transmitter on top. Mine has a problem with channels 5,6,7, and 8. Im getting an output of 26, 27, 28 and 30. The variable mode is the dial. The xtal mode takes the large 1/2 freq crystal. In xtal mode, no crystal, im getting a shift in the receivers frequency. Also, the 6cw8 pin 7 to ground has a 470 ohm 2 or 3 watt resistor that gets hot and eventually smokes. My deluxe transmitter has a wirewound cement 5 watt. This is the set that Im in need ofvthe schematics and service manual for. Been a journey and still nothing but the deluxe.
The American Radio Relay League (ARRL) is the national association for amateur radio, connecting hams around the U.S. with news, information and resources.
