M4000 Amplifier
Does anyone by chance have any info on this amplifier such as a schematic diagram? I have a resistor getting hot, the unit still puts out power but obviously has an issue. I have been over to CB tricks but nothing listed as just a M4000.
Thanks
Hello did you ever find out what resistor that was the color code on it or what have you mine is completely burnt out and it prevents it for cleanup or doing anything so it was definitely has to do with the key up circuit.
Hello, I need repair a M4000 amplifier, but I can't find information such as the schematic diagram or similar, if anyone has that schematic diagram, I would appreciate it. Or if anyone has images of the main circuit board.
the amp looks like it was modified and doesn't work.
my e-mail is jvalencia4312@gmail.com.
thank you
Just posting pictures of main circuit board in case someone needs component information.
Ok........I will call it upon myself.......
***Riiiiiiiiiiiise from your grave!! :D
But mainly because if this amp is truly an AB Biased amp or not.... Inquiring about it. :D
Yes, they were biased when built, however many units were modified to reduce the bias current in the wild.
I suppose without pictures of the inside, is reducing the bias current a good thing or was that opposite of what it needed to be? This is the board. (Taken off the internet.) M4000 internal board.webp
They were biased hard as built
I think @bob85 quoted almost 10 times the required bias current as built.
Making for a clean signal, the trade off is more heat and more current draw.
Reactions: doffo
That one also has the same resistor burning up. Top left above the relay, with the super long leads.
Reactions: doffo
Good eye. I was thinking about throwing a bid at the amp, but it may be a bit too much of a task for me to try and lower the bias on it.
  • @ Spanish:
    Where do i upload schematics
