Ranger Franken-radio
Eldorado828
UDX-828 in the Lonestar state (WDX-828)
Feb 21, 2016
4,877
9,675
523
The Panhandle of Texas
Well fellas, after months of selling radios off I've come to this. A TRE-797 that I was fixing to send down the road but decided to do something fun instead. It'll be fun or failure.
I get hobby burn out and have to get myself in an adventure to break the monotony.
I'm taking the tre-797 and installing an rci-x9 amp section onto it. Seems pretty simple, I hope.... but I might need some help along the way.
Wish me well!
I'll share how it goes as well as sharing photos.
For any that might be interested in this project, I was able to achieve quite a bit after some having to make minor mods.
The swr board had to go, the power jack hole had to be enlarged to fit the molex plug and some electrolytic caps had to be re-oriented to accommodate the amp section. There is no schemo for the X9 so I had to use the galaxy 94hp schemo as a reference to get everything wired in correctly.
So the finishing point for today, it's put together but it's a super snug fit. The x9 is all surface mount and the transformer on the board is in a different spot near the chassis side but in this one..... all through hole so some parts are quite a bit bigger and the transformer is right underneath the amp cover.... The wires had to be positioned perfectly for it to button up.
It's working just as it's supposed to but the audio sounds like total hell, and the meter needs to be adjusted. That'll be addressed in the coming days when time permits.
But so far, it's been successful-ish.... No magic smoke!
More to come
Update
I got the audio straightened out, it's much better. Before the amp transplant I had done the r176 mic amp resistor mod for more gain and it seems that it didn't play well with the added amp section. Now it'll be some fine tuning and this "abomination" should be ready to hit the airwaves! I'll report back with the final product!
Update
You and a lot of people on here are way above my head on a lot of the radio mods/ experiments. But it's cool to see everyone's projects.
Reactions: Eldorado828
I can say I'm pretty decent with a soldering iron but far from an Elmer by any means. Most of what I know was taught to me by the C.B.T. and WWDX academies and their generous Elmers who share their knowledge.
Reactions: Brother DXer
Update
I'll call it the tre-797 hp
The mission was a success and the radio turned out great. In all I installed the x9 amplifier section, new x9 covers, unlocked the clarifier, installed a ranger eb-2015 echo pcb and installed a vr on the main pcb for the tone control. It's quite the unorthodox radio for an ssb operator but I'm a trucker at heart so I built a trucker radio with ssb capability.
I used it all day today and made many ssb contacts with unsolicited compliments on the audio and signal. I guess it works!
It took about 2 weeks to do because life keeps me busy but the experience of putting it together was fun.
Just thought I'd share the trip with any that might be entertained.
Screenshot_20260110_203152_Video Player.jpgScreenshot_20260110_202948_Gallery.jpg
Update
View attachment 75622View attachment 75623
Glad it worked like you wanted it to. Very happy to hear that it has clean audio. Hoping to hear that audio someday.
Update
That is a cool radio, what mic are you running with it?
That is not that bad for a Franken radio! Well done! While I am not a huge fan of slapping amps onto radio's I have done it myself a few times in the 1990's. I mostly am against OEM's doing it since it is a terrible practice. When people do it themselves I do not have a problem with it other than it always being better not to have an amp bleeding heat into a radio.
Reactions: 999 and Eldorado828
  • @ Catalyst 122:
