Cobra 2000 GTL clock keeps resetting
Jimbo165
264
45
75
Southeastern Michigan
I have a cobra 2000 gtl base station radio. I can set clock and it keeps good time but when I turn on radio and then turn it off when done talking clock resets it self back to 12 oclock it will do this every time I turn it off any ideas on what the problem could be? Thank You Jimbo165
Sounds like the clock is powerd by your on/off switch, it needs constant voltage
Sent from my SGH-T599N using Tapatalk
Replace the 5.6 volt zener diode and also the associated switching transistor, it is for going between the clock and freq counter. Then replace the electrolytic caps that filter the DC supply and the small one that powers the oscillator / timer.When it goes bad, or shorts, due to bad electrolytics it shunts power (VCC) to gnd and therefore the clock resets. Sorry don't have a schematic in front of me at the moment to spell out the component designators for you at the moment, but you can find it in the service manual, or on cbtricks.com .
Do that, and the problem will be no more. But if you're having problems like that, 10 to 1, the radio isn't operating at optimum either. Sure it's probably functional, maybe an alignment could even get it back to being close to spec, but the caps are getting old. I would replace probably a dozen or so on the main radio PCB as well, and then realign.
Guys - these rigs are getting old.
Sounds to me like your CB has been hanging around with the wrong crowd: namely, those hippy long-haired VCRs in your house (we all know about their tenancy to sleep in all day and blink "12:00").
Tell your CB to get off the couch, get a job, and stop hanging out on the street corner with those good-for-nothing VCRs. :whistle:
Reactions: DainBramage
HAHAHAHA!!! Or, maybe it's waiting for it's Obama bucks... opps, I mean EBT CASH card needs reloaded for more scratchers, cigs and beer at 7-11. Sorry, I thought it went hand in hand with the previous post.:oops:
which cap? "small one that powers the oscillator"
what cap should I replace
All 10 or 11 of them. It's an old-age/mileage problem. Once the first one or two go bad, the rest of them won't be far behind. Troubleshooting "just one" capacitor is a waste of time. Time better spent replacing them all.
And a cheery footnote. The electrolytic caps inside the clock/counter enclosure tend to fail first because of operating temperature. It gets hotter inside that metal box than in the rest of the radio. The greater heat stress wears out the clock/counter caps first. But it's a sign that the three dozen or so on the main radio board will follow behind and start failing soon. They haven't been run as hot, but they're just as old.
Reactions: Cable Guy
Thanks Nomad, I did replace all the electrolytics on the main board but not in the freq counter board. Was trying to avoid messing with that freq board due to it's poor solder quality. Might just try and do the walkout method. I also do have a solder sucker. Just worried about messing up any through hole pads.
The walkout method is what I use. Much easier to suck the solder from a hole when there's no lead wire in it. Pretty sure I posted suggestions about handling the "orphan" pads that have no trace attached on the solder side. They tend to detach when you suck the solder from that hole. We use a "combover" using extra lead length to mimic the foil trace on the top side of the board, in case the top-side trace doesn't do the whole job alone. I'll see if I can track down that post.
Reactions: doffo
thanks Nomad I'll check it out. Thanks for your time.
