Cobra 29ltd no transmit 35-40
I've had 2 or 3 where the VCO voltage would become "jagged" on the scope at the extremes, not allowing lock on either the top or bottom 5 or 10 frequencies.
The issue remained after a recap, but was resolved with a "shotgun" style solder reflow in the area near the mixer/ varactors.... Sometimes it's just goofy stuff with what seems like no rhyme or reason.
Reactions: Night Stalker10
This is where a 'scope pays for itself. Watching the tuning voltage while you flip from channel 1 to 40 and back lets you make sure the voltage is well within the max/min limits, once for receive and then for transmit. A VCO with its slug set to 'almost' cover all 40 can buzz on a channel that it 'almost' locks onto. When L19 is almost set right, a tiny touchup could be all that's needed. I never recommend touching it if you can't watch the tuning voltage and see how it responds to touching L19's slug. A slug that's cracked or has a loose sliver will show a jerky response. Should only see smooth change in tuning voltage as L19's slug is moved either way.
It really sounds as if L19 is set so that the tuning VCO tuning voltage bumps its head on the ceiling on the top channels.
That's good info. I had a guy bring me his Cobra 29 with a no receive issue. A slight adjustment on L19 brought the radio back to life. Just another thing to keep in mind, or add to the little black repair book.
Sorry it’s taken awhile to get back everyone. I appreciate all the help I’ve received. After checking L19 after reading Nomad’s post turns out that it was just barely out, enough to keep the upper channels from transmitting. I set the radio to 40, keyed it up and started to adjust L19 and sure enough it started working. I had it hooked to my IFR so it was showing the output watts and it was on frequency. I went ahead and did the alignment procedures one more time just to check myself. I’m not sure if when I adjusted L19 to show 3.2 vdc if my meter is slightly off or what but it seems to be working fine now. So once again thanks everyone for the help.
That's good news, thanks for the update. I assumed that the L19 voltage effected all the channels, not just a few. I learned something new again.
Well actually I checked the voltage between channel 1 and 40 and tried to minimize the difference but i never could get them as close as I thought they should be. I can’t remember the exact figures but it was approximately 2.06 at channel 1 and 2.9 at 40. I was checking at tp2. Not sure if that’s the right place though but I adjusted l22 and it did change the voltages but that’s about as close as I could get them from what I can remember. As far as adjusting l19 I had it according to my meter at 3.2 volts but apparently it needed tweaked a little more to make channels 36-40 to work. Not sure why that’s above my pay grade but will hopefully understand it one of these days lol.
