best/easiest study system for tech and general license ?
#1DummyLoad
New Member
May 26, 2026
4
65
got the cart before the horse . got the FTDX10 (mars modded) from gigaparts a few weeks ago because they had $100 off and their 10 yr waranty for $10 . i have no ham experience and i'm only interest in SSB/voice at this time . i see many study courses recommended on you tube and while i think YT is a good source for general info on products , i rely on forums for expensive decisions and trechnical info . there's lots on info on on YT and forums on the ftdx10 but not much on forums about suggested study programs .
so what do you folks recommend ?
I used ARRL website stuff with question pool and practice exams, along with the hardcopy study guides found on Crapazon. Not particularly an ARRL fan and not a member but their stuff made the exams easy for me. With a bit of study and practice exams I found passing was not at all difficult. YMMV.
7 3 and good luck.
Great choice of radio by the way. Be sure to put up a good antenna to use it with to not waste all the potential that rig has.
Reactions: #1DummyLoad
I used HamTestOnline to get my Technician, General, and Extra, but that was 18 years ago. Paid one price and got all three. They have changed the pricing model since then and now you pay for each license level and your access only lasts 3 months.
As you take the practice tests the program focuses on your weak areas, drilling questions you get wrong more often than ones you get right. When your answer is wrong you can click a link to the teaching material to understand the topic and learn the correct answer.
Note that there is a new Technician test effective effective July 1, 2026 That means the question pool is changing.
P.S. Great Radio!
A local used the ham test online place and he liked it. I used and am using the below linked books to study. For me it was all about repetition, looking at the questions in the book over and over and then taking a practice test or two every week. You can create a user name and then log in to get started at the ARRL site.
You can take free as many free practice tests as you want, I will put that link below as well. With the radio you bought a General license will serve you best. With the Tech license you would be limited to 10m and 6m for the most part. With a Tech you can also use 2m and 70cm but you will need another radio for that. The DX10 is a great radio, I have a 991A and really like it.
Hamexam.org
thanks for the comments and recommendations . does anyone know if the tech test will be harder or simpler on july 1st ? for schiits agiggles i took the free tech test at HRP and got %54 without studying . and yeah , i'll be going for tech then general so i can make better use of the radios abilities .
I recently looked at the test pool and I have to say that if you have a general knowledge of radio you stand a good chance of passing tech with minimal study.
The general will focus more on allocations of frequency/bands , modes, stuff that you need to know where/what to operate.
Extra is were you are going to really get technical questions that will probably require a more intense study.
I will say that it's a lot different from the test I took many years ago that was way more technically challenging.
Best of luck with the tests.
Hamstudy posted a summary of the question pool changes. Near the bottom of the post they give their opinion about the new test
"If you’re planning to get your Technician license, don’t stress about which pool you’ll be tested on—the fundamentals are the same. The 2026 pool modernizes some questions around digital modes and clarifies a few regulatory details, but it’s not a dramatic overhaul. Study the material, understand the concepts, and you’ll do fine on either version."
https://blog.hamstudy.org/2025/12/the-2026-us-technician-question-pool-is-here/
thanks again :)
just noticed the ftdx10 went up to $1700 at DXE and others . $300 more than i got mine for 2 weeks ago . a few months back gigaparts said that yaesu were gonna go up so i guess i got mine just in time .
Reactions: NZ8N
Just took a practice extra test on hamexam.org and surprisingly passed! There were a few things I had absolutely no clue on and guessed but I still managed to get 80%. I should study a bit more on that digital mode stuff and then go try for it.
Edit: I feel like I got screwed on this one though because I know for sure cadmium sulfide is a big part of solar cells.
