Cobra 25LTD Classic
C91 as far as I can tell, will have to research it more when I get the radio back. Won't be the first time the board was marked different than the position.
When I recap, I usually follow the orientation of the old cap, I have seen too many incorrect silkscreen polarities. Sometimes I forget the orientation and reference the silk, but always write it down so if something acts wonky, I know which one to flip. Having a before pic is a lifesaver.
Reactions: Smokinone
I found this Taiwan 25 like the one we're working on here. Kinda fuzzy as not a very good pic, but it seems to show that I have the new one in wrong..but fuzzy pic and fuzzy eye sight.
Reactions: Cable Guy
You're correct, I'm getting sloppy in my old age.
Yeah, hard to see the details, and I wish I had one here to look at, but I'd bet you a dollar it's backwards. I don't see many 25s these days.
Easier to see, from CBTricks.
I looked at those and it seems the positive goes to ground, but not sure if the board actually has the positive position marked correctly. If the board is marked correctly, then it's installed correctly after my re-cap, if not, and that we're not sure of, then I installed it incorrectly. I need to get the radio back in my hands.
Thanks much guys for the research and good eyes.
edit: I seem to remember now that i think about it as it was the only 6.3 volt cap on the board.
That limiter circuit works on the negative going portion of modulation on that line and is what it senses for limiter action, that cap is tied to the base of a pnp transistor, so that's why the cap has positive side to ground, because the voltages going through there are negative with respect to ground.
The stress of removing a small electrolytic makes it no longer reliable. We keep the popular value caps handy and just replace any that have to be removed.
Its not the stress of removing it that I was concerned with. When you apply reverse voltage, the cathode forms oxide and the anode oxide becomes damaged. It can lead to reduced capacitance, increased ESR, and sometimes shorts that make things interesting in circuits with more power than this one. Its just good practice.
But since it probably didn't get hammered in this particular application, maybe its fine.
Reactions: doffo
Isn't this cap already kinda running reverse polarity as the positive lead is to ground? Or am I missing something.
I know reverse polarity can actually burst or explode an electrolytic cap, from experience, or lack thereof, I have had that happen to me.
I would imagine the voltage and current are very minimal as the original cap was a 6.3 volt cap, lowest value in a radio I have seen. The replacement was a 25V 105C, but I will definitely check it and replace it.
Reactions: doffo
