Lafayetts Telstat 140 SSB now just low power
Techno1
244
71
49
New Hampshire
Was using the radio this morning working fine then something happened now just about 2 watts on Am and about 2 watts on ssb both lower and upper.
Radio dead on frequency and receive is great
No burn marks on the bottom pc side.
I pulled bothe finals 2sc 1969 and 2sc2166 abd both are ok.
Seem like rf out power just dropped in radio.
Any suggestions Im going to get out the service manual later tonight and study it and see if i can figure this out
Forgot to add there is very little modulated audio going out on AM its now backwards modulation and ssb will get a 2 watt carrier this is with a turner hand power mic.
Radio was doing about 15 watts SSB and about 5 watts AM now all low rf out.
thanks for any help
Well i searched the forum and found some post on low rf power for the telsat 140.
I replaced the balance modulator and I do have 8v on pin 6 with transmit.
I checked c78 for short and that is fine.
The radio is tuned to 5watts AM with very little swing and 6watts ssb.
When i talk in mic it will do 2 watts ssb and whistle in mic it will peak to 6 watts.
Am dead key 5 watts and peak to 6 watts forward .
Receive is fine good incoming signal and audio.
So im getting very little rf audio on the transmit carrier
Any help appreciated
What test equipment do you have? If you have a 40+ MHz oscilloscope with x10 probes, go through the TX line and see where your RF is falling off.
My scope is out to lunch looking for another good used one.
the problem is the ssb power is only 5-6 watts out.
I have aligned the radio to the service manual and is on frequency but very low audio input to the rf carrier.
Radio was working well then bang low ssb power out
Receive signal is great and also audio but low ssb power
Anyone have any Idea why the ssb is low power going out like 6 watts peak whistling and just talking about 2 watts out
I have tried to check out and struck out.
Well on RV2 I can adjust the ssb from 1 watt to about the 5 watts its putting out low saying ah into mic if i whistle i can get about 8 watts and radio is all tuned for peak power. Am power is about 5 watts with very little forward swing
did you adjust SSB Mic Gain? Give it some more if it can.
I tried and still low power Radio is all set adjusted to factory spec Im waiting for some HG final replacements to see if its a final even though they check fine.
Seems like I stated low audio into the ssb carrier or maybe be a electro cap shorted to ground. that will be my next step checking voltages. I will also try a video to post here later that will be much better to explain.
And radio receives fine and transmits on frequency just low output ssb power
Reactions: doffo
When you turn the ALC (sideband limiter) trimpot does it make any difference to the sideband peaks?
Nomadradio
Any suggestions what might be the problem with low power ssb on the telsat 140 radio. Was doing about 14 watts then stopped all of a sudden. I have new finals on the way gonna change and see what happens a 2sc 2166 and a 2sc 1968 gonna replace with HG finals.
thanks
The trimmers are working as I can adjust from 0-5 watts on am and also 6 watts on ssb so they are working.
It seems that some kind of limiting transistor or a dried-out inter-stage capacitor in the audio path is simply shorting the microphone signal to ground and clamping the swing.
