I saw that, but I'm not sure if they can pull 12+Khz. If you think so, I will try.Did u try Kens electronics he shows a 10.040 and a 10.070 you might be able to use a trim cap with it.
The xtals I got I was able to trim a full channel with a 40pf yellow trim cam.I saw that, but I'm not sure if they can pull 12+Khz. If you think so, I will try.
Is the xtal needed for a 02a chassis what model radioI saw that, but I'm not sure if they can pull 12+Khz. If you think so, I will try.
Yes, a Colt Excalibur ssb 02a.Is the xtal needed for a 02a chassis what model radio
10.070-10.0525=.0175 which should be able to bend with a trim capI saw that, but I'm not sure if they can pull 12+Khz. If you think so, I will try.
Its Bomar crystal in Middlesex N.JYes, a Colt Excalibur ssb 02a.
I will call ken in the morning and get one of each. Thank you. If that doesn't work out, I can pursue other options.10.070-10.0525=.0175 which should be able to bend with a trim cap
No, I'd rather just replace it if I can.Did you try to re attach the pin/wire
If you need I can send you a 40+ and 40- crystal no charge if you want to add extra channelsNo, I'd rather just replace it if I can.
